Guys, I'm having a tough time getting a Garrett speed sensor setup on an ADL. Has anyone had any experience setting one up with an ECU, logger or Dash?
The sensor is powered by 5V and then there is a 5V output frequency that changes according to the wheel speed.
According to the instructions from Garrett, you are supposed to take the output frequency of the sensor, and multiply it by a factor based on the number of compressor blades in the system.
I've tried to set it up based on frequency and simply did the math to get to table values in a custom calibration, but I still can't get the ADL to calculate any values.
When I take the signal output and put it to an analog channel I get, 4.89V when the turbo is not spinning and, 5.05V when the wheel is spinning at idle. So, I know that the sensor is spitting out some sort of output. I just can't seem to get the math right in the channel, or reading the channel. Do you guys have any ideas? Thanks.
