Ls2 map sensor calabration
Postby Daniel on Sun Nov 21, 2010 5:51 am
Hi all
I am running a Ls2 with a M800 and are having problems with the MAP sensor.Its the stock one and at the moment
i have it set up as a delco 100kpa.I know this must be wrong as i am getting a error sometimes and its doing silly things when i pull the logging after a run.
Has anyone run a STD Ls2 MAP sensor?
Thanks For you help
Daniel
Danic Performance
Daniel
Re: Ls2 map sensor calabration
Postby stevieturbo on Tue Nov 23, 2010 12:58 am
Why not get a Mityvac and calibrate it manually ? That way there is no guesswork going on.
stevieturbo
Postby Daniel on Tue Nov 23, 2010 9:38 pm
I would be sure that someone has done one.
Danic Performance
Daniel
Postby Martin on Wed Nov 24, 2010 3:21 am
Ive never had issues using the same cal. Under high vacuum they tend to pull output below 0.1v that could cause you to see strange things. Have you tried setting Diag Lo lower?
Postby Daniel on Wed Nov 24, 2010 5:32 am
I will try that tonight .
Danic Performance
Daniel
Users browsing this forum: Bing [Bot] and 15 guests
