Did my delco manifold temp sensor die?
Postby bazeng on Wed Nov 17, 2010 4:14 pm
Hi guys, after a few good runs down the quarter, my air temp after the turbo/before the intercooler has been reading incorrectly.
I noticed on the calibration page that temps max out at 150 degrees C. I believe the turbo would be generating higher temps than that. Could this have damaged the sensor? It now reads 160 deg C and as it heats up, the reading drops! Strange. Any suggestions? I'm logging with an sdl.
bazeng
Re: Did my delco manifold temp sensor die?
Postby Martin on Thu Nov 18, 2010 12:29 am
It wont last long there...too hot and too violent for the exposed sensor tip to survive if you have it right by the turbo`s discharge. The Delco failures I normally see for a sensor in this position is the complete dislodgement of the sensing element inside the little cage.
The Bosch pressure/temp sensor found in the BMW335 lasts better. (Havent broken one yet, but I guess still not the right sensor for the job, just used it because I had it)
Common discharge temps 160-170DegC. Higher pressure ratios on turbo`s normally make more temps. (look at your compressor map) I guess discharge temps can vary between turbo`s, boost, etc etc as much as there are different turbo`s :)
Postby bazeng on Thu Nov 18, 2010 3:18 am
What sensor do you suggest I use?
bazeng
Postby bazeng on Sat Nov 20, 2010 10:12 am
Guys, any suggestions on the sensor I should be using? What do you have with the same thread and with a temperature range that safely reads under 300 ish degrees c
bazeng
Postby bazeng on Mon Nov 22, 2010 9:43 am
Anybody please?
I do have a honeywell egt probe I can use... Is that the only option?
bazeng
