Bosch motorsport coil 0 221 604 014
Postby toby on Fri Aug 22, 2008 2:10 am
Does anyone have any experience running these coils with M800 series ECU's?
M-Tech - MoTeC Dealer UK
toby
Re: Bosch motorsport coil 0 221 604 014
Postby RossB on Mon Aug 25, 2008 12:51 pm
We haven't done much in the way of testing but if it is settings you need:
Volts Dwell
6 10.0
8 5.8
10 3.6
12 2.6
14 2.1
16 1.8
Pin 1 ECU, Pin2, Ground, Pin3 Bat V.
RossB
Postby stevesingo on Tue Aug 26, 2008 9:08 am
stevesingo
Postby toby on Tue Aug 26, 2008 9:06 pm
Thanks guys. I had heared some reliability issues from MoTeC Aus via MoTeC Europe and am just specing some coils for a turbo suzuki engine.
toby
Postby stevesingo on Wed Aug 27, 2008 7:14 am
Toby,
I'd be interested to hear any info on these as I was planning on using them on my BMW S14 (E30M3), running M800.
Steve
stevesingo
Postby toby on Thu Aug 28, 2008 11:35 pm
Events have overtaken me! There are no connector plugs currently available here from Bosch for this coil for at least 3 weeks. I will be using std Jap bike stick coils.
toby
Postby stevesingo on Fri Aug 29, 2008 6:08 am
I know Swindon Race engines (UK) have recently fitted another S14 with these coils, you may want to give them a call.
What engine are you fitting them to. My plan B was VFR800VTEC Coils.
Steve
stevesingo
Postby toby on Fri Aug 29, 2008 9:16 pm
The Bosch coils were going on a turbo GSX1400 but as I said, I am now going to use std Jap stick coils from any of the modern Jap 1000cc bikes (non Cdi).
toby
Postby Apex Speed Tech on Sat Aug 30, 2008 7:43 am
That's all you need. I've made 550hp at 40psi of boost on GSXR1300's bored out to 1600 using the stock coils.
Neel Vasavada
Apex Speed Technology
Los Angeles, CA 90064
310.314.2005
www.apexspeedtech.com
Apex Speed Tech
Postby Arve Flaat on Mon Jan 05, 2009 6:35 am
Hello
Have used the coils and they work very well. The coil are not expensive and since the transistor is integrated in the coils it give very few wiers/easy wiering.
The connectors are:
Bosch: part nr D 261 205 367 and can be bought at www.BSA-motorsport.de
The connector is made of Sumitomo. The part nr is: 6189-0779.
Regards
Arve Flaat
Arve Flaat
