GPS Time shift
GPS Time shift
Postby richib2002 on Thu Jul 08, 2010 1:14 am
I have just fitted a 10hz GPS module to a Drag car. This is mainly for a speed signal. The trouble is in i2 standard there is not a GPS time shift facility when in a "Drag Race" project. Has this been omitted for a reason or is it just an oversight?
Regards
Rich
richib2002
Re: GPS Time shift
Postby Martin on Fri Jul 09, 2010 4:43 am
Is the 10Hz new?
Where did you get it?
Re: GPS Time shift
Postby richib2002 on Fri Jul 09, 2010 6:25 pm
Brand new from Motec Europe last week. GPS speed signal is around 0.2 of a second out
richib2002
Re: GPS Time shift
Postby Martin on Tue Jul 13, 2010 2:55 am
With what did you compare it?
What make of GPS is this?
Re: GPS Time shift
Postby Chris on Wed Jul 14, 2010 7:29 am
Yes the GPS Corrections is not in the Drag Racing standard project. Adding that feature is on the to do list, but I do not have any time frame for when this will be completed.
The 10 Hz GPS is likely a unit made by MoTeC Systems USA. You can find a spec sheet online by changing your region in the bottom right corner of the screen, then going under downloads/datasheets and selecting the RaceGrade GPS
http://www.motec.com.au/filedownload.ph ... docid=2745
The time shift should be -0.13 for the 10 Hz model and -0.11 for the 20 Hz model, based on my testing.
Chris Brown
Chris
Re: GPS Time shift
Postby Holmz on Wed Jul 14, 2010 9:17 pm
Chris wrote:Yes the GPS Corrections is not in the Drag Racing standard project. Adding that feature is on the to do list, but I do not have any time frame for when this will be completed.
Chris Brown
Chris,
Good info.
Is the GPS speed:
1) differenced between the current position and the last position,
2) using some doppler
3) or ??
Holmz
Re: GPS Time shift
Postby jhidley on Fri Oct 29, 2010 2:56 pm
What are the units of time shift for the 10Hz Race Grade GPS unit? Seconds or msec? The field available for this time shift has a default unit of msec.
Jack Hidley
jhidley
Re: GPS Time shift
Postby Chris on Sat Oct 30, 2010 1:44 am
I believe that GPS speed is based off doppler effect and not the positional information.
The time shifting required in the prior post was listed in seconds, hence -0.11 seconds (110 msec) for our 20 Hz model and -0.13 seconds (130 msec) for the 10 Hz model.
Chris
Re: GPS Time shift
Postby jhidley on Sat Oct 30, 2010 3:00 am
Chris,
Thanks.
Jack Hidley
jhidley
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
