I have a turbo engine equipped with a 3-bar map sensor using M400. I brought my car to a shop for tuning and the tuner has 20+ yrs of experience with Motec and they have a full shop of Porches/Lambo/Ferarri running Motec as well.
Two days into the tuning, my engine blew up, therefore I'm currently in the process dropping in a freshly built engine.
During the down time, I download the M400 config file and was going through reviewing the setting and realized that the tuner was using Throttle % as the load point on the fuel map instead of using map sensor's pressure as load point?
During the tuning session, the custom made intake manifold cracked which causes leaked. I'm not saying this is the reason why the engine blew up BUT!! using the throttle % as load point meaning that if there is any leak anywhere in the intake, the pressure will be different with the same throttle % which can cause either running lean or rich right?
Ok.. enough said! What is the up sides and down sides of using either throttle % or Map as the load point for fuel map? I want to use this as a decision making of whether I should be using the same tuner for my car after the new engine has been dropped in. Personally, I'd use nothing but the map/pressure as the load point on my fuel map table.
I need your opinions! Thank you...
andy
