I am almost finished with installing the Motec system on my motorcycle, but had a couple of questions regarding the proper set-up of the M880 using a DBW4 to control two DBW throttle bodies. I would appreciate any help you can offer.
1. I am suffering from an “Error EDBW[] CMD Shutdown” for the two DBW throttle bodies. I can tell that the ECU is properly determining the required TP (TP Reqd). In addition, I was able to properly calibrate both throttle bodies using the DBW4 software. Specifically, during calibration of the DBW4, the raw values for each throttle body changed properly depending on its position. However, in addition to the CMD Shutdown error, the M880 diagnostic screen identifies Throttle Position A and B as 102% even though the throttle bodies are closed. Any ideas as to what the problem might be?
2. Are there any application notes for setting up DBW configuration using the DBW4 in conjunction with the M880?
3. I understand that I can configure the outputs of various Motec Devices as inputs to the M880 using the Input PINs Setup tables. Are the outputs of the DBW4 identified in the same manner as the Expander boxes, i.e as “Ex []"?
Thanks.
