Making a track map?
Making a track map?
Postby Holmz on Thu Oct 14, 2010 10:59 pm
So I am interested in how to make a track map...
I can weave around to cover the bounds of a track - but the track I am want to make a map of is custom - otherwise I would download it.
So I went out and walked a course with the ACL in pocket, along with the GPS and LiPo battery, and antenna... All on the spare loom.
I walked both the inside and the outside edges of the track, and then ran the racing line before I realized that I am not much of a runner.
Now what?
I see inside, outside and drivers line - on the auto generate option. Bit that did not work well as the file also had the entrance to the course on it.
So I decided to split the file into 3 parts.
There are some sections where there are trees and the # of GPS satellites goes to zero.
No problem with the original file, there is just a hole on the graphs in the lat;lon;lat when the #-sats went to zero.
But for the split off files (i.e. *_1 , *_2 ,*_3 files), and the lat and lon go to zero (without a hole in the graphs) - which does not help when looking at the map - as the scale now just from Australia to include 0;0.
But it does not do that with the first file before splitting? - what is up with that?
Do I need to split the file and export it as a new motec file?
So I am a bit lost here...
I might call - would this be a Mark or Jamie question?
Holmz
Re: Making a track map?
Postby DarrenR on Thu Oct 21, 2010 4:27 pm
Hi Holmz,
Firstly on the exported file not making GPS Position '0' = N/A in the exported file has been fixed a long time ago. What version are you using??
Have a read of the attached document, it explains the use of GPS's with our dashes, GPS beacon setup and how to make the inside/outside lines in i2.
Cheers,
DTN0014_GPS_Beacons_and_Track_Mapping.pdf
(298.56 KiB) Downloaded 2136 times
Darren Reynolds
DarrenR
Postby Holmz on Tue Oct 26, 2010 2:22 am
DarrenR wrote:Hi Holmz,
Cheers,
Thanks again !
Holmz
