Ref/sync suggestions (NEED HELP)
Postby Tommy on Sat Oct 16, 2010 7:12 am
I have started my project (nightmare) and hitting some brick walls.
1982 Ferrari 308 GTSi. Converting to COP and SMFI via M800. The problem that I'm having is trying to understand and resolve my ignition issue. The 308 has a pick up at the flywheel to check the engine speed and position. Dual distributors controlled by Magneti Marelli Digiplex MED801A. I guess the flywheel could be used as a reference?? What's the best way to provide the 800 with the sync signal to make it work?
Any suggestions will be greatly appreciated.
Tommy
Re: Ref/sync suggestions (NEED HELP)
Postby Holmz on Sat Oct 16, 2010 9:37 am
Tommy wrote:I have started my project (nightmare) and hitting some brick walls.
The tabs on the back of this (Non-Fezza) flywheel are used to provide magnetic or hall trigger.
Do you have anything like that on your flywheel?
Picture 6.jpg (23.54 KiB) Viewed 18383 times
Holmz
Postby Tommy on Sat Oct 16, 2010 9:48 am
No i don't...it's a regular flywheel
Tommy
Postby Holmz on Sat Oct 16, 2010 1:04 pm
Tommy wrote:...
If there is a pick up at the flywheel - then that can be used.
What does it look like?
Holmz
Postby Tommy on Sun Oct 17, 2010 12:39 am
After having a closer look at the flywheel (still in the housing) and with the help of some Ferrari members I can verify that there are 3 magnetic pick ups.
1 for cylinder 1-3 TDC
1 for cylinder 5-8 TDC
1 for engine speed .
Will I be able to utilize these pick ups to achieve non wasted spark and SMFI?
PS some Ferrari members have installed a reference a wheel at the crank to get the ref, however they have not used Motec. Instead they used an electromotive system to control the ignition system.
Tommy
Postby Tommy on Sun Oct 17, 2010 1:14 am
Tommy wrote:No i don't...it's a regular flywheel
Correction..
I was able to get an image of the flywheel.
Tommy
Postby jaymonkey on Wed Oct 20, 2010 5:17 pm
Hi There,
I am looking at a similar project what make/type of COP are you using ?. I was thinking of using either Bosch P100-T or P50:-
http://www.bosch-motorsport.de/pdf/components/ignition_coils/Coil_P100_T.pdf
and :-
http://www.bosch-motorsport.de/pdf/components/ignition_coils/Single_P50_P50_M.pdf
The depth from the top of the spark plug to the cam cover is about 90mm, both of the above maybe too long ?
Any suggestions ?
Cheers Jay
jaymonkey
Postby Holmz on Wed Oct 20, 2010 11:05 pm
jaymonkey wrote:Hi There,
and :-
Any suggestions ?
Cheers Jay
Nice - I've been looking for something like these.
I take it that the ion sensing feature is used for knock ?
Holmz
Postby Tommy on Thu Oct 21, 2010 12:09 am
[quote="jaymonkey"]Hi There,
and :-
Any suggestions ?
Jay,
it all depends on the length.
I'm using the COP's from Denso found on motorcycles. Perfect fit and length for my application.
Tommy
cop 1.JPG (12.47 KiB) Viewed 18180 times
Tommy
Postby Scott@FP on Thu Oct 21, 2010 8:17 am
For boosted apps the P100-T is The Way, real motorsport coil not an OEM unit with OEM spark energy.
Scott@FP
