SLM via ADL
Discussion and support for MoTeC's Shift Light Module
SLM via ADL
Postby szekeris on Fri Oct 08, 2010 8:42 pm
Dear Sire,
I hawe a ADL old version. I use a SLM for shift light. It is working well. How to setup the bright without
use a new software.
I want to use a switch for dimming the light.
Best Regards
Istvan
szekeris
Re: SLM via ADL
Postby DarrenR on Mon Oct 25, 2010 1:56 pm
Hello Istvan,
So you have the SLM operating from a manually set up CAN transmit template in the ADL - Version 3.2 software?
It is difficult to dim the SLM using the ADL, but it is possible. It involves calculating the value for each light and adding a value based on the brightness switch using the channel maths.
It can be complex depending on your configuration. 3D tables can also be used if not used for other functions.
Darren Reynolds
DarrenR
Return to SLM
