Scott@FP wrote:AWD cars don't always slip the same wheels every time, and there's really no true gnd speed reference as you pointed out. Entirely possible and fairly frequent to have all 4 wheels slipping at nearly the same rate, losing forward drive (loss of lat G)at lower speeds. AWD (fully differentiated, not progressive ala Nissan and Porsche)is more likely to slip the fronts first, but defining the fronts as Drv Spd still leaves a couple of holes in the strategy. It might work out OK, have to play with it some more, really only want to prevent one wheel from blowing off over bumps or at low speeds and briefly cut power to get it back in line. Usually what seems to happen is traction loss in one wheel leading to loss in another on the opposite axle.
