in description of item is written : The coil charges when a 5 volt signal is applied to pin A, and fires when the voltage drops to zero.
here it is http://www.diyautotune.com/catalog/ign1 ... p-394.html
can i use it with motec ?
ms_logging wrote:in description of item is written : The coil charges when a 5 volt signal is applied to pin A, and fires when the voltage drops to zero.
Marc wrote:I think the logic signal from the MoTeC can drive this coil directly.
