ORB Fuel Cut
ORB Fuel Cut
Postby bing on Tue Sep 14, 2010 12:11 pm
I was trying to setup down shift throttle blip but its is not working because orb fuel cut become active.
What are the reason for ORB fuel active when i have ORB disable and it was set to ign cut?
i have look check map over and over again can't find why.
I have all over run fuel disable already.
i have included a log file and map for reference if someone could have a look at it.
Thanks,
Brian
20100913-1102200.ldx
Log.idx
(289 Bytes) Downloaded 849 times
20100913-1102200.ld
log.id
(439.25 KiB) Downloaded 825 times
Ap2-DBW4.8.e35
Map
(72 KiB) Downloaded 850 times
bing
Re: ORB Fuel Cut
Postby bing on Sat Sep 18, 2010 2:03 am
Anyways, i have found the problem.
It is the ORB Idle RPM,
I have no idea it will active ORB fuel cut when ORB Switch has been disable and Ign Cut were selected.
Thanks,
Brian
bing
Users browsing this forum: No registered users and 41 guests
