is this coils complatable with m400 ?
Postby ms_logging on Fri Sep 17, 2010 10:47 pm
in description of item is written : The coil charges when a 5 volt signal is applied to pin A, and fires when the voltage drops to zero.
here it is http://www.diyautotune.com/catalog/ign1 ... p-394.html
can i use it with motec ?
ms_logging
Re: is this coils complatable with m400 ?
Postby Marc on Sun Sep 19, 2010 3:00 am
ms_logging wrote:in description of item is written : The coil charges when a 5 volt signal is applied to pin A, and fires when the voltage drops to zero.
This is build-in ignitor coil.
I think the logic signal from the MoTeC can drive this coil directly.
Marc
Postby ms_logging on Mon Sep 20, 2010 5:12 pm
Marc wrote:I think the logic signal from the MoTeC can drive this coil directly.
yes , but i need to know exactly.
ms_logging
Postby virkhan on Tue Sep 21, 2010 6:44 am
I use this coils on my vauxhall engine and it works great. I have m800. You have to choose (fall trigger) on ignition setup.
virkhan
Postby ms_logging on Tue Sep 21, 2010 5:17 pm
thanks ! ;)
ms_logging
