4th axis on AUX output possible ?
Postby 20B on Sun Sep 12, 2010 6:38 pm
Can I run a fourth axis ( 4D table ) on an M800 Auxillary output PWM table ?
Mazda 1993 RX7
20B N/A engine
20B
Re: 4th axis on AUX output possible ?
Postby fel1979 on Mon Sep 13, 2010 5:22 am
I don't think you can, but if you have a another spare AUX you can use another one to use as a reference. ..
You can use the result of your 1ST AUX to influence the 2nd AUX Table. and use the result of this to work where you need it.
Regards
fel1979
Postby RossB on Tue Sep 14, 2010 11:33 am
No there is no 4D tables on Aux outputs, they are only on Ignition, Fuel and DBW.
RossB
