mhd wrote:Mate
I'm surprized, the file I sent you is for the same as your cars, and my car ECU# is the same as yours and I also use the same your injectors (D 1100CC), I think you should try to pull out the AVEC Slonoid Conector, and try to replace the spark plugs, for now Use OEM Pluges ( NGK ILFR6B)
if does not work againe try put back OEM ECU and OEM fuel injector and check again
Good Luck
