Hi/Lo injectors during cranking
Postby Polux RSV on Mon Aug 23, 2010 9:02 pm
I have a setup with man injectors as primary, and top feed inj as secondary.
Setting the balance table with all 0, pri injectors only, I can still see the secondary spraying at first injection and during cranking.
Is this behaviour correct ????
Angelo
Polux RSV
Re: Hi/Lo injectors during cranking
Postby IDP on Mon Aug 23, 2010 11:56 pm
Table with all 0's is actually all secondary injectors....
IDP
Postby Polux RSV on Tue Aug 24, 2010 1:56 am
Sorry, I made a typo. I wrote 0 instead of 100.
Thanks IDP.
Angelo
Polux RSV
Postby RossB on Thu Aug 26, 2010 1:04 pm
Use the Primary BAlance on/off and Secondary Balance on/off parameters in the Secondary Injection setup to switch the injectors off when they are not being used.
RossB
