Injector current setup
Postby Polux RSV on Tue Aug 17, 2010 8:34 am
What will happend if I set the current too low in General setup->fuel->setup ????
Is it possible the injector will not completely open, resulting in lower fuel flow ?????
Angelo
Polux RSV
Re: Injector current setup
Postby Polux RSV on Thu Aug 19, 2010 8:35 pm
No Motec guy to explain if injectors are current limited or only PWM driven ?
Angelo
Polux RSV
Postby SprinterTRD on Thu Aug 19, 2010 9:09 pm
You answered your own question!
The fuel flow will not be consistent as the hold current may not keep the injector open.
SprinterTRD
Postby Polux RSV on Fri Aug 20, 2010 1:38 am
Thanks. I suspected this behaviour because changing values in fuel tables had no effect on lambda readings.
But as an electronics engineer, I still would like to know if the injectors outputs use FET transistors with PWM, or transistors with programmable current limiter :mrgreen:
Angelo
Polux RSV
Postby SprinterTRD on Fri Aug 20, 2010 8:28 am
If you scope the injector output you will see how the current limiting is done.
SprinterTRD
Postby Mazi on Mon Aug 23, 2010 10:12 am
Mazi
Postby Polux RSV on Mon Aug 23, 2010 9:13 pm
Thanks Mazi, exactly what I needed to understand parameters meaning. :mrgreen:
Angelo
Polux RSV
