M800 Injector timer output
Postby 20B on Thu Aug 19, 2010 8:51 am
Ok here is a tricky one for the experts !
Is it possible to have Inj output 7 switch on then off lets say every 8 seconds continually but only when the rpm is above 500 rpm and the engine temperature is above a certain point ?
Could this be done on the ECU or is this SDL / ADL territory ?
Mazda 1993 RX7
20B N/A engine
20B
Re: M800 Injector timer output
Postby SprinterTRD on Thu Aug 19, 2010 1:06 pm
Call it a intercooler spray bar and its done.
SprinterTRD
Postby Martin on Fri Aug 20, 2010 1:41 am
I dont think the spraybar funtion will listen to engine temp...maybe run it in your SDL, think it will be easier there with 2 timers.
Postby SprinterTRD on Fri Aug 20, 2010 8:34 am
You can do it if you feed the spray bar function output into a input on the ECU. Then use that input channel on a axis of a user defined table with temp as the other axis on another AUX output which controls the injector.
SprinterTRD
Postby Sander on Fri Aug 20, 2010 12:58 pm
Thats pretty clever sprinter. Cool idea.
Sander
Postby Martin on Sat Aug 21, 2010 3:03 am
Ohh now I understand how you would do it :) Or just use the Sparybar output`s DC as one axis on the Aux table instead of wiring
Postby 20B on Sat Aug 21, 2010 11:48 am
Care to show how it would be done ?
Mazda 1993 RX7
20B N/A engine
20B
Postby Scott@FP on Sun Aug 22, 2010 6:30 am
When you go into the table axis setup, hit the 'select' bar, when it pops up check the 'show non-sensor channels' box and all kinds of wonderful possibilities for experimentation occur. All the aux inj ign DC's can be an axis among many other things.
Scott@FP
Postby 20B on Sun Aug 22, 2010 12:42 pm
Wow I never really ever noticed that sneaky little checkbox ! Lots of goodies in there to play with.
I'm still a bit unsure of how to set it up, can anyone do a quick screengrab of the table settings you would use to make INJ output turn on then off continually for a given time above a predetermined engine temp ?
Mazda 1993 RX7
20B N/A engine
20B
Postby Scott@FP on Tue Aug 24, 2010 2:17 pm
function 102 thermo fan might do what you want, except the lowest frequency appears to be 1 Hz. Then you can set up its table to 1 or 2 axis operation.
Scott@FP
