20B wrote:...with pretty good success...
Out of interest what engine is it?
I would still trigger the accel enrichment from TP but you will find that you do not need as much.
You can have a seperate baro compensation though if you find that there are changes in mixture that the MAP compensation is not correcting.
RossB wrote:...
\You could do a compensation based on the duty cycle of the idle valve to help overcome this as an alternative.
Users browsing this forum: Google [Bot] and 0 guests
