Hi All:
I´m doing a Peugeot 206 XS with Multiplexed CAN OEM Dashboard, could be possible doing a custom data send to send the rpm and ET information to the OEM Dash? I´m trying to found the peugeot´s CAN protocol.
Regards
Alejandro
PeteS wrote:HI Guys
Just some side info for you on this subject.
Yes our normal baud rate is 1 MB however you can set up an M800 to communicate on 500kb so that it may communicate on the Factory vehicles CAN Bus
There is a new setting in ECU Manager under
Tools;
Options;
Communications;
CAN data rate;
Here you can specifi for the laptop to talk to the ECU at 1Mb or 500kb
The reason I mention this is that if you plug into the latest Subaru for example, that has one of our Plug in ECU's, it is likely your laptop wont connect. You will need to go and change the setting in ECU Manager to 500kb.
We have some CAN templates in the software that are sending messages to the Factory dash at 500kb
PeteS wrote:Doh,
You are right,
I have had a version of this for so long now I had assumed it was release.
Sorry
The one you will likely see is version 3.5, it has just gone beta so it should be out soon.
Keep an eye out as its got lots of extra stuff in it.
Regards
