Bosch motorsport coil 0 221 604 014
Postby toby on Fri Aug 22, 2008 2:10 am
Does anyone have any experience running these coils with M800 series ECU's?
M-Tech - MoTeC Dealer UK
toby
Re: Bosch motorsport coil 0 221 604 014
Postby RossB on Mon Aug 25, 2008 12:51 pm
We haven't done much in the way of testing but if it is settings you need:
Volts Dwell
6 10.0
8 5.8
10 3.6
12 2.6
14 2.1
16 1.8
Pin 1 ECU, Pin2, Ground, Pin3 Bat V.
RossB
Postby stevesingo on Tue Aug 26, 2008 9:08 am
stevesingo
Postby toby on Tue Aug 26, 2008 9:06 pm
Thanks guys. I had heared some reliability issues from MoTeC Aus via MoTeC Europe and am just specing some coils for a turbo suzuki engine.
toby
Postby stevesingo on Wed Aug 27, 2008 7:14 am
Toby,
I'd be interested to hear any info on these as I was planning on using them on my BMW S14 (E30M3), running M800.
Steve
stevesingo
Postby toby on Thu Aug 28, 2008 11:35 pm
Events have overtaken me! There are no connector plugs currently available here from Bosch for this coil for at least 3 weeks. I will be using std Jap bike stick coils.
toby
Postby stevesingo on Fri Aug 29, 2008 6:08 am
I know Swindon Race engines (UK) have recently fitted another S14 with these coils, you may want to give them a call.
What engine are you fitting them to. My plan B was VFR800VTEC Coils.
Steve
stevesingo
Postby toby on Fri Aug 29, 2008 9:16 pm
The Bosch coils were going on a turbo GSX1400 but as I said, I am now going to use std Jap stick coils from any of the modern Jap 1000cc bikes (non Cdi).
toby
Postby Apex Speed Tech on Sat Aug 30, 2008 7:43 am
That's all you need. I've made 550hp at 40psi of boost on GSXR1300's bored out to 1600 using the stock coils.
Neel Vasavada
Apex Speed Technology
2931 S. Sepulveda Blvd Suite F
Los Angeles, CA 90064
310.314.2005
www.apexspeedtech.com
Apex Speed Tech
Postby Arve Flaat on Mon Jan 05, 2009 6:35 am
Hello
Have used the coils and they work very well. The coil are not expensive and since the transistor is integrated in the coils it give very few wiers/easy wiering.
The connectors are:
Bosch: part nr D 261 205 367 and can be bought at www.BSA-motorsport.de
The connector is made of Sumitomo. The part nr is: 6189-0779.
Regards
Arve Flaat
Arve Flaat
