Welding
Welding
Postby Holmz on Tue Jul 27, 2010 10:01 pm
Not knowing exactly which are to put this in but...
When welding on the chassis, what is the proper thing to do"
1) Take out the ECU and datalogging ACL?
2) Unplug the ECU/ACL connectors?
3) Put foil on the connector pins?
4) Take out battery and connect positive to ground?
5) Nothing?
6) Some combination of the above?
Holmz
Re: Welding
Postby yotamhks on Tue Jul 27, 2010 10:17 pm
when doing any form of bodywork that includes welding i would mostly disconnect the battery,
and also disconnect the ecu from engine harness altough without any voltage it should be fine.
i have seen alot of welding performed without non of the above and nothing happaned but i think that
better safe then sorry.
if you weld nea and ecu or harness then yes,
aluminium foil anf mybe underneath the aluminium a saugey rug with water soaked into it.
yotamhks
Re: Welding
Postby Mazi on Wed Jul 28, 2010 7:44 pm
And disconnect all sensors with integrated electronic like MAP, MAF, Hall and Optic sensors.
Mazi
Return to Tuning discussions
Users browsing this forum: Bing [Bot] and 2 guests
