Displaying AFR on a PLM connected to an M800
Discussion and support for the MoTeC PLM and LTC's
Postby TORC on Tue May 11, 2010 6:01 pm
I have a PLM connected to an M800.
It appears that when a PLM is connected to an M800, the PLM can only display as lambda, not AFR.
I would like to see AFR on the display as that's what's immediately meaningful to me. Is there a workaround to do this, or is it something that may be possible in the future?
TORC
Re: Displaying AFR on a PLM connected to an M800
Postby J&R on Tue May 11, 2010 10:36 pm
Reconfigure the plm to read AFR
J&R
Postby TORC on Mon May 17, 2010 10:57 pm
Setting it up to display AFR didn't work - I just got dashes displayed on the PLM. That's when I checked the manual and found it says that if 's plugged into an M800 (or ADL), the table MUST be lambda. If the table's lambda, then that's what the PLM will display.
TORC
Postby RossB on Tue Jun 08, 2010 4:37 pm
There are 2 tables in the PLM. These tables are used for the display, analog output and CAN messages. Each of these functions can use either of the tables and you can load different tables to suit your requirements. So you can load table 1 for Lambda and table 2 for AFR. You then use table 1 for your CAN output to the M800 (CAN output) and Table 2 for your display. The attached configuration shows how this is done assuming you are using gasoline.
AFR Display Lambda CAN.P11
(944 Bytes) Downloaded 1962 times
RossB
Postby TORC on Fri Jul 02, 2010 1:55 pm
Thanks for your help Ross.
Not sure what I did before but I've just done it again and it works fine :oops:
TORC
Return to PLM & LTC
