Fast_Moto wrote:I am trying to connect a Motec M880 to an AIM MXL. The ECU is able to communicate with the engine while it is off and cranking. However, the CAN connection is interrupted once the engine is firing. Any suggestions as to what the issue might be?
Fast_Moto wrote:As it turns out, the MXL can loose communications during cranking and won't properly reset communications. Restarting the MXL once the engine is running takes care of the issue.
IJ. wrote:Fast_Moto wrote:As it turns out, the MXL can loose communications during cranking and won't properly reset communications. Restarting the MXL once the engine is running takes care of the issue.
Change the power lead to the dash to one that is on 100% of the time during cranking, depending on where it's connected now some cars drop all loads that aren't related to firing the engine while the starter is engaged.
Holmz wrote:IJ. wrote:Fast_Moto wrote:As it turns out, the MXL can loose communications during cranking and won't properly reset communications. Restarting the MXL once the engine is running takes care of the issue.
A diode and a capacitor can also help here...
