Motec M880 and AIM MXL
Postby Fast_Moto on Tue Jun 22, 2010 2:16 pm
I am trying to connect a Motec M880 to an AIM MXL. The ECU is able to communicate with the engine while it is off and cranking. However, the CAN connection is interrupted once the engine is firing. Any suggestions as to what the issue might be?
Fast_Moto
Re: Motec M880 and AIM MXL
Postby Holmz on Thu Jun 24, 2010 11:18 pm
Fast_Moto wrote:I am trying to connect a Motec M880 to an AIM MXL. The ECU is able to communicate with the engine while it is off and cranking. However, the CAN connection is interrupted once the engine is firing. Any suggestions as to what the issue might be?
Do you have the resistor across the CAN line?
Would suspect so otherwise it would not work with the engine off (what resistance do you measure?)
Seems like interference though... Are the can wires tightly twisted around each other?
Holmz
Postby Fast_Moto on Fri Jun 25, 2010 3:55 am
As it turns out, the MXL can loose communications during cranking and won't properly reset communications. Restarting the MXL once the engine is running takes care of the issue.
Fast_Moto
Postby grcforce327 on Sat Jun 26, 2010 11:36 am
I'm running a AIM Strada with an M800.It's been working fine for 2yrs, without ever having to reset after startup.
grcforce327
Postby Fast_Moto on Tue Jun 29, 2010 8:31 am
Not all units/installs have that issue, but is not an unknown problem.
Fast_Moto
Postby IJ. on Tue Jun 29, 2010 9:02 am
Fast_Moto wrote:As it turns out, the MXL can loose communications during cranking and won't properly reset communications. Restarting the MXL once the engine is running takes care of the issue.
Change the power lead to the dash to one that is on 100% of the time during cranking, depending on where it's connected now some cars drop all loads that aren't related to firing the engine while the starter is engaged.
IJ.
Postby Holmz on Tue Jun 29, 2010 12:00 pm
A diode and a capacitor can also help here...
Holmz
Postby Martin on Tue Jun 29, 2010 5:14 pm
Have you tried this setup to keep a device alive during cranking? What size cap did you end up using? Must be fairly large!
