LTC Mgr Send Failures - but Communicates - Do This or Die!
Discussion and support for the MoTeC PLM and LTC's
Postby TunedByShaneT on Fri Jun 18, 2010 2:59 am
LTC Manager seems to be communicating with the LTC but any attempt you make to send CAN information, Upgrade Firmware, Air Calibrate the sensor results in a failure to send message.
Upgrade your UTC Firmware.
You can upgrade the UTC by going to Start - Programs - MoTeC - USB to CAN Adapter - Upgrade UTC Firmware
If you do this - your problem will be solved and you will go off blissfully into the sunset whilst reading your lambdas.
If not - you will endure endless hours of mental torment culminating in injury or even severe death.
Luckily Simon W saved my life - so Im paying if forward.
Shane T
Regards,
Shane Tecklenburg
Technical Consultant
ST Consulting
21602 Surveyor Circle
Huntington Beach, CA 92646
714-318-5845
shaneteck@yahoo.com
TunedByShaneT
Return to PLM & LTC
