Park/In Gear input
Park/In Gear input
Postby F6R on Mon Jun 14, 2010 2:09 am
Can an input be configured to add a fixed value of idle control duty cycle when the transmission is engaged into gear?
F6R
Re: Park/In Gear input
Postby IJ. on Mon Jun 14, 2010 9:03 am
Not sure if this is the "correct" way to do what you want but I'd look at the initial position table for the idle control and add a Y axis based on the switched input from the Trans selector and have it add/subtract some initial as needed.
IJ.
Postby F6R on Wed Jun 16, 2010 4:00 am
Thanks I will have a go.
F6R
Postby F6R on Wed Jun 16, 2010 4:10 am
Cant get a Y axis up on any of the idle control tables.
What will work though is by using the power steering switch input and then the idle control set-up has that provision.
F6R
Postby IJ. on Wed Jun 16, 2010 7:36 am
Very strange I have X/Y axis on my Idle Normal Position table.
Which software/firmware are you running?
IJ.
Postby F6R on Thu Jun 17, 2010 5:41 am
Am running 3.52J..........it's probably me.
F6R
Postby IDP on Thu Jun 17, 2010 6:14 am
When viewing the Idle normal position table hit the A key.
You will then have the dialog box to add the 3rd axis.
IDP
Postby F6R on Wed Jun 30, 2010 12:15 am
Thanks.
F6R
Users browsing this forum: No registered users and 52 guests
