Making a rev counter "lie"?
Postby Chris Wilson on Sat Jun 12, 2010 6:49 am
If I was to want my stock Nissan 6 cylinder rev counter to lie and read about 4800 RPM when the engine is really only turning about 3800 RPM how would you set it up? Please don't ask why...... :) Thanks.
Chris Wilson
Re: Making a rev counter "lie"?
Postby stevieturbo on Sun Jun 13, 2010 8:32 am
I'm sure its possible to change the output.....but trying to fool a noise test. Naughty naughty.
Play with the settings in Auxiliary outputs/tacho ?
stevieturbo
Postby Martin on Tue Jun 15, 2010 12:20 am
Adjust>Auxiliary Outputs>Aux out>Parameters>CALIBRATION
Has your nissan got fully variable camshafts?
Postby Chris Wilson on Tue Jun 15, 2010 12:27 am
No, it's on fixed cam timing, would playing with that output signal interfere with the correct activation of some VV timing set ups?
Thanks for the replies!
Chris Wilson
Postby Martin on Tue Jun 15, 2010 9:48 pm
Nope, its purely the outputs calibration...So whatever is reading from the OUTPUT will be affected
