M800 Tacho output
Re: M800 Tacho output
Postby Daniel on Mon Jun 07, 2010 7:07 am
Well if its a 5 volt wave i ned a 12 volt one.
Danic Performance
Daniel
Postby Daniel on Mon Jun 07, 2010 8:54 am
Just spoke to Motec about this and will try there fix and will let you know how i go.
Daniel
Danic Performance
Daniel
Postby IJ. on Mon Jun 07, 2010 9:24 am
Bit odd if it needs a 12v signal most dashs are 8v Dan, they drop the voltage needed to run them so a low battery won't affect them as much.
Interested to hear how you go with it!
IJ.
Postby MarkMc on Mon Jun 07, 2010 9:45 am
A coil negative tacho is not like an ECU driven tacho so you cannot run them directly from the ECU. A coil negative side give a very large back EMF pulse that drive the tacho, an ECU driven tach works of a much simpler frequency drive from the ECU.
The way around this is to instal an iductive coil of some sort to provide the big back EMF spike you need for a coil negative tacho, we usually use a relay coil.
I have attached a basic wiring diagram
COIL NEG TAC DRIVE.JPG (50.23 KiB) Viewed 10077 times
Postby Daniel on Mon Jun 07, 2010 2:04 pm
Hi Mark
Thanks very much for the info you have given me.
I had spoken to Peter today about this and said the same thing or
try a 1k resistor from 12volts to the signal wire.
I have just done the 1k resistor and works great.
Will test drive the car this afternoon and see how it goes.
Thanks again for everyones help
Daniel
Danic Performance
Daniel
Previous
