immediate fuel accel
Re: immediate fuel accel
Postby Martin on Thu Apr 22, 2010 2:23 pm
Drop it just enough that the accel fuel works well. If accel happens to easily closed loop will not work, Remember that closed loop cuts out as soon as there is accel fuel.
Im still wondering what the actual accel value is that will trip closed loop..........cause its not anyting >0
Postby Marc on Sun May 16, 2010 3:19 am
Thanks for all guys quickly reply. :)
I set accel threshold to several value lower than 25.
I feel that is near 2 or 3 and sensitivity 200 is the best.
But is not very perfect.
I have try a lot of combination setting. :roll:
But I still like to use a lean lambda 0.97 from idle
Is it must set to rich lambda 0.87?
Or lean map is impossible improve the problem. :?
Please give me some suggestion.
Marc
Marc
Previous
