Yamaha R1 Fly by Wire and Variable Velocity Stacks
Postby stevegibson on Fri May 07, 2010 12:19 am
Is there any literature around on how to connect and configure the 2007-2008 R1 fly-by-wire and variable velocity stacks?
Steve
stevegibson
Re: Yamaha R1 Fly by Wire and Variable Velocity Stacks
Postby Holmz on Fri May 07, 2010 3:49 am
Holmz
Postby stevegibson on Sat May 08, 2010 8:31 pm
Bumpety - Bump.
Anyone got any info?
Steve
stevegibson
Postby IDP on Sat May 08, 2010 11:03 pm
Your motec dealer will give you the PID's for the DBW.
Don't use the ones from the R6 file.
Wiring will be as the R6 file though.
Aux 1 & 2 drive the throttles
2x AV in for TPS and 2x AV for Driver throttle TPD
Secondary intakes as in attached pdf.
DEV-RPT-007_01--Yamaha Velocity Stack Control.pdf
Yamaha intakes Pdf
(210.57 KiB) Downloaded 1897 times
IDP
Postby stevegibson on Sun May 09, 2010 7:39 am
Nice one thanks!!
stevegibson
Postby AlanB on Sat May 15, 2010 5:03 am
Here is a later version of the velocity stack control document. There was a mistake on the Aux3 polarity on page 4.
DEV-RPT-007_02--Yamaha Velocity Stack Control -- GENERAL RELEASE.pdf
(202.21 KiB) Downloaded 1642 times
Alan Bell
MoTeC Europe Ltd
AlanB
Postby Holmz on Sat May 15, 2010 1:19 pm
AlanB wrote:Here is a later version of the velocity stack control document.
Thanks Alan
Holmz
Postby Holmz on Wed Mar 02, 2011 7:41 pm
Back to hijacking the right thread...
So there is a connector with a red and a black wire going into the servo.
So Aux7 and Aux8 go to this red wire according to the documentation.
Does this affect being able to use 8 injectors, with each injector on a separate injector circuit?
I assume that the current needed for the servo is small enough to not be a worry, or is that why 2 aux outputs are used?
Holmz
Postby dudule01 on Wed Mar 02, 2011 8:27 pm
look at the pdf file page 2, you'll find the explanation about the use of both Aux outputs:
"As MoTeC M800/M880 ECU’s (herewith referred to as ‘the ECU’) have only one H Bridge it is normally necessary to use an
additional control unit for one of the servo motors (a MoTeC DBW4).
This document describes how the ECU can be setup to control variable velocity stacks without the use of the dedicated H Bridge
circuitry (Aux1 and Aux2), thus leaving the H Bridge free to run the DBW."
dudule01
Postby Holmz on Thu Mar 03, 2011 6:11 pm
dudule01 wrote:Hi,
Thanks dudule01 - But I am still half lost...
The TB I have the older drive by cable version.
So not quite sure why I need 2 Aux outputs hooked up?
The timer I get.
Having an one aux table for enable and one for disable to do the hysterysis I get and Nitrous I understand.
Probably just as important is for me to understand the idle circuit as it is drive by cable.
Holmz
