Knock Module Voltage Supply
SKM and OKM
Postby incontrolsteve on Thu Apr 01, 2010 7:06 pm
Hi
Does anyone know if the SKM will run from a standard 12v supply instead of the stated 8v? I know Beacons will. I have a car that has an available 12v but no 8v as we are using the new M1 and no 8v available. Any thoughts anyone.
Steve
incontrolsteve
Re: Knock Module Voltage Supply
Postby Martin on Thu Apr 01, 2010 8:38 pm
M1? On what are you using it?
Postby RossB on Tue Apr 06, 2010 1:59 pm
Steve, You can run the SKM from the 6v3 pin. We do not recommend running it from 12V.
RossB
Postby incontrolsteve on Tue Apr 06, 2010 4:12 pm
Thanks Ross, thought that might be the case , didn't want to overload the 6v3 output though.
incontrolsteve
Return to Knock Modules
