Hall Sensor Recommendation
Postby rx7brain on Fri Apr 02, 2010 3:22 pm
Can anyone recommend a Hall Sensor to suit a trigger wheel of the following dimensions-
117mm (4.5") OD
5mm thick
5mm teeth spaces (35 tooth + 1 missing)
5mm tooth height
The data sheet on the Motec ones state 10mm gap and 6mm thickness min requirements.
I have been told by some they will still work fine though.
rx7brain
Re: Hall Sensor Recommendation
Postby RossB on Tue Apr 06, 2010 11:56 am
They may work but you will probably have problems at high RPM. WHy don't you use a magnetic sensor?
RossB
Postby rx7brain on Tue Apr 06, 2010 12:24 pm
thanks for the reply.
I will use a Magnetic, I just thought Hall type was "better" (more presice).
In saying that the data sheets on the mag type state 10mm gap and 6 mm thickness also.
rx7brain
