Hi
I'm having issues with getting the correct gear displayed on the SDL.
I've inputted the gear ratios in the software but it displays a gear below what it is in.
I am getting the speed input from the AUTRONIC SM4 ecu which is correct (calibrated correctly in the Autronic software).
The Autronic then sends it out to the datastream to the motec.
I'm thinking that the SDL requires to calculate the speed internally?
The SM4 displays the correct gear and speed.
Can I use the SM4 to output the gears to the SDL?
I'm thinking I could send it via the datastream into the SDL into a channel but before I do that, any suggestions to what it could be?
Also, in NEUTRAL, the gears go all over the place, is this correct? Is there a way to fix this?
Baz
