Looking for a bit of advice.......
I'm currently building a Lancia Integrale Rally car which is running an M800 and a Sport Dash. The engine loom is already made and the engine/dash side of things is sorted.
The car now needs all the road going ancillarys wiring up. I want to use the Motec PDM system but can't decide which one to choose.
Here is a list of the parts which will need power.
internal/map light
12v supply for in car things like Sat Nav etc
Shift light
HID headlamps
sidelamps
main beams
indicators
hazard warning lights
fog lights
brake lights
Reversing light (if you want one, not MOT requirement I think)
internal dash lamps for main beam, indicators, and alternator charge
Windscreen wipers and windscreen washer pump
electric windows
Ignition off/on/start
fused supply for engine loom switched by ignition switch
Fused supply for dash switched by ignition switch
Fused supply feed for fuel level sensor and necessary wires in loom to operate
fused supply for speedo ecu
lighting supply for dash lights on Tacho, fuel level guage and Motec (ie 12v switched feed that comes on when sidelights or headlights on.
Relay controlled supply for rad fan (trigger feed from this to come from the Motec Dash as opposed to thermo switch)
Relay supply for chargecooler pump (triger feed from Motec Dash as above)
High current relay supply for main fuel pump to be controlled by Motec ECU with feed from existing engine loom. Lower current relay supply for pair of lift pumps with relay control from Engine ECU loom.
alternator exciter feed circuit
heated front and rear screens
The list is quite a large one but I feel that the car would benefit from the Motec PDM system.
Thanks in advance,
David.
