I am running a davies craig electric water pump running a water temp sensor and coolant pressure sensor. I want to install a 'flow' sensor that can basically measure if the water pump is working and flowing coolant around the motor and at what rate, I have had a bad experience with electric pumps failing and not being able to detect the rise in coolant temp quickly enough.
There are several industrial units availiable but would be interested to see if anyone else has done the same thing.
I would prefer not to use ultrasonic but something more cost effective like a paddle wheel type sensor.
It will be connecting to an SDL or M800.
