We are running an M48 with an expander for a 6 cyl wasted spark setup. The ECU software is set to 3 coils, mode 100. the crip is 485 with a test advance of 20deg.
THe expander is getting 12V once the starter button is applied(from the relay) and the ground is good. THere is no real output voltage from the IEX to the igniters. What should the measure voltage be from the IEX? Also, the M48 seems to have a contant 12Vdc into the IEX, is this correct?
TIA
