Bosch abs M4 can template
Postby gregpe on Mon Mar 08, 2010 10:27 pm
Hi.
Just trying to have correct values form abs unit but for some reason i can't.
Bosch provide can protocol but i'm not sure is correct.
or maybe i'm doing something wrong....
please let me know if somebody is using this system and have correct can tamplate?
gregpe
Re: Bosch abs M4 can template
Postby figgie on Tue Mar 09, 2010 6:57 am
Well a couple of things to keep in mind.
1. Make sure that the speed of all devices on the CANBus is the same. So if the xDL is 1Mb/s, the Bosch M4 has to also be at 1Mb/s.
2. The hex address has to be known. If it is decimal. convert to hex.
3. Migt need t custom cinfugre something in the ADL2/3 manager. Perhaps MoTeC can help.
figgie
Postby Martin on Wed Mar 10, 2010 5:08 am
Im using the M4, but I was not aware that the CAN data is available.
Mind to share it?
Postby gregpe on Wed Mar 10, 2010 9:59 pm
Yes you can have lat g, long g, YAW, wheel speed, switch position.
I manage to have sw. position and wheel speed. ( took me few hours:)) when i will find yaw and G's i can share:)
gregpe
Postby Martin on Fri Mar 12, 2010 6:48 pm
Im trying to get the Template from Conti, they apparently do the programming of it....let me know if you find anyting. If I find anyting Ill let you know
Postby ETATech on Fri Jun 11, 2010 1:57 am
I have seen the CAN protocol used by the ABS on the Bosch manual.
Have you already tried with that template?
ETATech
Postby NathanS on Tue Jun 15, 2010 11:24 pm
I have seen a couple of different CAN protocols for the Bosch M4 ABS system, I have attached an ADL3 config with the templates setup for what I think is the most recent one. This is for an M4 ABS system that is transmitting at 500K, the CAN protocol for the system that is transmitting at 1M is slightly different.
The templates in this config haven't been tested though so I'd appreciate it if you could let me know how you get on.
I've sent the templates in a file as I have changed some of the names due to the use of general purpose channels, if you open the config you can save the templates to the correct folder they will then be selectable in your config file.
Bosch M4 ABS CAN comms rev1 - 500K.zip
(4.61 KiB) Downloaded 2098 times
NathanS
Postby shrek69 on Mon Jun 27, 2011 10:35 am
Is there also a config for the M800?
Want the speedsignals over CAN for traction controll.
shrek69
Postby Martin on Wed Jun 29, 2011 7:00 am
The M4 has 4 wired speed outputs as well.
Pin 8, 10, 12 and 14
Wire to digital inputs for speed.
Postby georgemcf on Tue Feb 10, 2015 3:26 pm
did anybody happen to see if this works? I am about to try and do a template for an M4 abs system and a new C187 dash.
How do I know if it is transmitting at 1m of 500k?
georgemcf
Return to ADL3, SDL3 and CDL3
