by NathanS on Tue Jun 15, 2010 11:24 pm
I have seen a couple of different CAN protocols for the Bosch M4 ABS system, I have attached an ADL3 config with the templates setup for what I think is the most recent one. This is for an M4 ABS system that is transmitting at 500K, the CAN protocol for the system that is transmitting at 1M is slightly different.
The templates in this config haven't been tested though so I'd appreciate it if you could let me know how you get on.
I've sent the templates in a file as I have changed some of the names due to the use of general purpose channels, if you open the config you can save the templates to the correct folder they will then be selectable in your config file.
- Attachments
Bosch M4 ABS CAN comms rev1 - 500K.zip
- (4.61 KiB) Downloaded 2290 times
