So, I am having similar issues with my 2007 STI rally car. Today at a test day the car simply decided it would no longer start. Up until that point, the car has always run fine. I have fuel pressure. Battery was ok. Couldn't find any borked grounds. Had spark, although intermittent so I tried a friend's cam and crank sensors. Nada.
Once we tried everything mechanical without success, we turned to the ecu. When I got home and as able to hook up to the ecu, I could see that I was getting the following sync error (note that the MAF is currently disconnected so I expect the MAF and IAT errors but since it is a MAP based tune, I don't figure that's an issue):
I also read a thread to capture ref data so I did that with the ecu powered but when I crank I lose connection to the ecu so.... looks like a flat line to me (no waveform whatsoever). Does this mean my crank sensor is kaput? Or maybe my cam sensor? I find that odd because I already tried others from working vehicles with no success. Or is that just because I couldn't do a capture with the vehicle actually running?
I am not a tuner so I had the car professionally tuned but I am short on time as I have a rally later this week so thought I would try here. Any help you guys can offer would be greatly appreciated.
Cheers, JC
