Fuel Injector Selection
Re: Fuel Injector Selection
Postby stevieturbo on Sat May 02, 2009 1:33 am
Maybe I missed it...but have you actually stated how much fuel flow you actually need ?
stevieturbo
Postby timlothian on Sat May 02, 2009 9:28 am
No I havnt.
According to the Motec rule of thumb for injector sizing I would need: Engine power/number or cylinders x 5.5cc/hp = 80x5.5/2 = 220cc
As I have said before, being a motorbike engine of only small capacity and power, I wont need very large injectors. Seeing as though the most commonly available injectors are for cars, the flow rate was not my primary design consideration as almost all injectors for cars are going to flow more than this.
In my injector selection I have looked at the flow rates only to ensure they are not stupidly big (eg: 1000cc is unnecessary). I dont expect to be running very high duty cycles.
cheers
timlothian
Postby stevieturbo on Sun May 03, 2009 3:00 am
Keeping things simple...wouldnt the easiest place to source injectors then...be from a motorcycle that already uses fuel injection ?
I know ive seen quite a few throttle body setups for sale on ebay etc complet with fuel rails and injectors. It's bound to be a decent starting point ?
stevieturbo
Postby timlothian on Sun May 03, 2009 11:15 am
I did consider this much, however these fuel injectors aren't always your standard bosch, rochester....etc type fuel injector and as such, finding information about them is quite difficult.
While I'm sure I could find the flow rate of these injectors somewhere on the net, I am also interested in detailed information regarding spray pattern and spray angle. Afterall this project is part of my undergraduate thesis and it is important that I do some proper design behind things.
I know it is possible to determine spray angle and all the details through measurement of the injectors on a test bench, however I don't plan on purchasing 10 different injectors to test in the hope that one will be what I want.
As I've said before, the engine has relatively deep ports and in order to spray onto the back of the valves, and not allover the walls of the ports, I need an injector with a tight spray angle. The only injectors I have found at the moment with enough detailed information are the bosch injectors and as such I will be choosing one of these.
cheers
Tim
timlothian
Postby MarkMc on Tue May 05, 2009 10:45 am
Just to clarify the rule of thumb injector sizing.
(Horse power required per injector x 5)/desired Lambda = cc/min
E.g. N/A, 500hp, 8 cylinder engine. 500/8 = 62.5hp/injector
62.5 hp x 5 = 312.5 cc/min
Because it is a naturally aspirated the Lambda will be about 0.88 at high load/rpm; 312.5/0.88 = 355.11cc/min
And just to finish off you would obviously choose an injector that was bigger rather than smaller. You could even add in a duty cycle adjustment, lets say 65%
355.11/0.65 = 546.32cc/min. Again choose the closest injector "erring" on the larger side.
Postby driftshop on Mon Mar 01, 2010 2:21 am
"lag" values for injectors, including USDM, JDM aftermarket and some factory injectors used for other applications :)
http://injector-rehab.com/kbse/lag.htm
driftshop
Postby Holmz on Sat Mar 06, 2010 5:48 pm
timlothian wrote:I did consider this much, however these fuel injectors aren't always your standard bosch, rochester....etc type fuel injector and as such, finding information about them is quite difficult.
As I've said before, the engine has relatively deep ports and in order to spray onto the back of the valves, and not all over the walls of the ports, I need an injector with a tight spray angle. The only injectors I have found at the moment with enough detailed information are the bosch injectors and as such I will be choosing one of these.
Tim - You were not joking about the difficulty in searching!
If you find any with narrow spray angles I would appreciate any info.
Sent you an emil as well to your edu.
Holmz
Postby timlothian on Sat Mar 06, 2010 9:39 pm
Randal, bringing up an old post!
With regards to the post, get a hold of Mark McCoy of any of the Mote guys. I have now graduated uni and so will not be organinsing one for our sae team.
With regards to the fuel injector. I did find one, cant remember whether I specifiec it above. The injector was a bosch one, as they are the only people who make available decent information. The injector had a 20 degree spray angle. If you look at the bosch-motorsport website you will find some good stuff!!
cheers
timlothian
Postby timlothian on Sat Mar 06, 2010 9:42 pm
by the way - email has changed: t.lothian@unswalumni.com
timlothian
Postby Holmz on Sun Mar 07, 2010 12:10 am
timlothian wrote:Randal, bringing up an old post!
With regards to the post, get a hold of Mark McCoy or any of the Motec guys. I have now graduated uni and so will not be organinsing one for our sae team.
cheers
Thanks Mate!
I'll search on the bosch site.
What are doing now that you have graduated?
Randal
Holmz
PreviousNext
