Hello there
I would be happy the get some assistance. This is my set up:
two stroke,two cylinders ,4 injectors (two in pairs),crank trigger 30- 2 teeth.magnetic. Engine is big bang (both cylinders have same TDC.
I want to be able to tune the cylinder sparks and fuel seperately for each cylinder. As far as I know the engine should be syncroniced with sync sensor. Is it possible to put sync sensor to two-stroke ? Or is there another trick to do ?
With regards
Mike
