Another old ECU with gadgets...
Postby Mazi on Tue Feb 16, 2010 12:38 am
ECU ??
Serial 9109020 P/N CEM-3D-M
EPS 3.3 C4
Is it possible to connect this calibrator and black box to the M4 with ser. no. <3000?
Mazi
Re: Another old ECU with gadgets...
Postby Mazi on Wed Feb 17, 2010 11:14 pm
:) I can't believe!
ECU is still alive! Calibration box is working, PC connection running EMP3V3 on XP is also OK. FW version is 3.21
Is there any documentation still available?
Mazi
Postby RossB on Thu Feb 18, 2010 8:38 am
That is a very old 2 Group ECU. DOcumentation is very limited but I have attached a scan of the hand controller manual. THe wiring drwing can be downloaded from the MoTeC web site http://www.motec.com.au/downloads/downloaddatasheets/.
Hand Controller Manual.pdf
(1.62 MiB) Downloaded 1837 times
RossB
Postby dangerousdan on Thu Apr 29, 2010 11:20 pm
WOW, I would like to have a look inside the circuit in the transmit modem. Are you able to post a photo of the circuit? I need to make on of these that works.
dangerousdan
Return to Old ECUs
