M4 & PLM WIDEBAND
M4 & PLM WIDEBAND
Postby yotamhks on Tue Feb 09, 2010 9:31 am
my M4 is all option's enabled exclude lmabda. i am using advance tuning. i own Motec PLM wideband.
can i use Quick lamda with it or i must open lambda option?
for further knowledge, is it possible to use it without any options opened at all?
thank you!
yotamhks
Re: M4 & PLM WIDEBAND
Postby Martin on Wed Feb 10, 2010 2:08 am
YOu dont need the lambda upgrade if you have a PLM
Have a look in the M4 manual to see how to wire it up.
Postby yotamhks on Wed Feb 10, 2010 6:44 am
but do i have to have advanced upgrade for using quick lambda?
yotamhks
Postby RossB on Wed Feb 10, 2010 8:35 am
Quick Lambda will work without Advanced Functions.
RossB
Postby bazeng on Mon Jul 19, 2010 9:58 pm
I'm thinking of utilising the quicktune option.
What is required exactly?
Which is the recommended option?
How effective is it?
bazeng
Postby yotamhks on Mon Jul 19, 2010 11:52 pm
since the original post i have tested PLM and M4-M48 many times and it wokes likes charm.
it is good for me to fine tune a fuel map.
notice that only when you press Q the quicktune performes.
yotamhks
