by Martin on Sun Feb 07, 2010 11:39 pm
Hve you got the offsets set correctly?
I do the offsets with the cam control solenoids unplugged to get both cams to 0. If you make a "normal position" table, both cams will use this table, and if there is a difference between the 2 in how they react it might cause some headaches.
Have you logged the DC of the 2 cam actuators? are they not maybe on the limit you have specified in the cam control setup?
Is reaction slow? Add P gain
If they are reacting okay but just not reaching the target, maybe add some I gain.
Ive found that same is you on non-stock BMW N52s, but luckily there is only one inlet and one exhaust so the normal position table helped.
