I currently have an Electric Water pump that I supply 12V to via a relay, the relay controlled via an output from the motec
I want to input a control circuit, having the water pump on half its output until a certain water temp is reached, probably around 75-80deg, then have the WP on full as before
Any ideas?
A simplistic relay circuit would be to input a 2nd relay circuit, having the motec control relay(1) - (half output) -from engine start obtained via a 6ohm 100W resistor in series with the 12V supply circuit
Having Relay(2) controlled via the motec switching on from say 75-80deg providing the pump with the full output (12V/6-7A)on the 2nd circuit and switching relay(1) off, when relay(2) is energised
The only problem I can see here is I'll be using 2outputs - of which I'm lacking already and the fact my voltage output is defined by the hardware(resistor) that I install, I'm not entirely sure yet whether half the output will be sufficient as I still have to test
No thermostat is being used currently, the aim of this circuit is to allow the engine to heat up but to make sure it does not overshoot i.e not overheat before the pump can bring temps under control
I suppose for test purposes, I could use a pot to find out exactly how much resistance and therefore voltage is needed before the temps overshoot
I do not want to have the Water pump completely off until I get to temp as I've been told that heat spots in the engine can appear very quickly with no flow
I also intend wiring a third circuit to the pump with a manual switch so I can have the WP on whilst I'm cooling my engine trackside with ign off
