upgrading software on m800
Postby zxrjohn14 on Thu Jan 21, 2010 7:52 am
i have version 3.50 on the ecu and wondered what are the advantages to upgrading to the 3.52?
i plugged everything in to upgrade but a warning come up saying about this can cause problems.
has anyone encountered any problems?
is it advisable to stick with what i've got/know?
many thanks for any help
john
zxrjohn14
Re: upgrading software on m800
Postby ejenner on Mon Feb 01, 2010 8:46 pm
Often best to stick with what you know. However, if the new features are worth having then upgrade. I was using version 2.3 because my rolling road recommended it for simplicity - at the time I was only doing very simple ignition timing control. On advice of Motec I upgraded to 3.5.1 but now doing the full works so was worth having something a bit better than before. But the difference between 2.3 and 3.5.1 are massive. Things like REF/SYNC capture are very valuable tools and not available in the earlier version.
These are the updates: Extended data entry range on Input Setup Warning Hi/Lo values, Axis Setup tables, Lambda Calibration tables, Timer Maximums and CAN funtion Address ranges.
Probably not worth upgrading unless you want any of those features in particular.
ejenner
