I am running an M800 with a methanol fueled supra. I am planning to use injector outputs 1-6 for firing the primary injectors, and I want to use injector outputs 7&8 to control 2 fuel injectors that I have upstream of the throttle body.
What I am unclear about is how I need to set these up in the Motec software: Do I just put them as secondaries I and then go from there using a standard firing order for the engine? I am confused because my number of secondary outputs does not match the number of primary outputs so I need a little help/explanation of how to properly set this up.
