MDC2 Fault
Discussion and support for MoTeC's Mitsubishi and Subaru Diff Controllers
MDC2 Fault
Postby weka325 on Sun Jan 10, 2010 9:38 am
dear all,
after installind the MDC2 in my Evox with the M800 plug and play, the ASC is permenantly flashed in the dash board and there are a word which said MAINTENANCE REQUIRED and the programs freezed in snow progrem, did any one faced this problem before?
weka325
Re: MDC2 Fault
Postby DarrenR on Tue Jan 12, 2010 11:31 am
Is your Evo X an RS model??
The M800 plugin and MDC2 is designed for the RS model only which doesn't have ASC on any we have seen.
Regards,
Darren Reynolds
DarrenR
Re: MDC2 Fault
Postby weka325 on Tue Jan 12, 2010 12:05 pm
my Evox GSR, what about the SERVICE REQUIRED massage, also i cant switsh between the snow and tarmac and gravel progrem, its held in snow.
what can i do?
weka325
Re: MDC2 Fault
Postby Swen35310 on Mon Feb 04, 2019 9:28 pm
I have the same problem GSR 2009 ASC Turned off in ETACS and rear passive differential mounted on the car .I can’t change modes - frozen on snow -and service maintenance.Can You help?
Swen35310
Re: MDC2 Fault
Postby Swen35310 on Wed Feb 06, 2019 5:37 am
I found solution
Regards
Swen35310
Return to MDC and SDC
